Environment Set Up - Installing the Cognite SDK package
Forum|alt.badge.img+7
I am able to run the code in the given Google Colab sheet. But when I am running the same code in my IDE (Spyder or Jupyter),  I am facing Cognite Connection Error in step 3.
Error message:
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\connectionpool.py:467 in _make_request
    self._validate_conn(conn)
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\connectionpool.py:1096 in _validate_conn
    conn.connect()
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\connection.py:642 in connect
    sock_and_verified = _ssl_wrap_socket_and_match_hostname(
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\connection.py:782 in _ssl_wrap_socket_and_match_hostname
    ssl_sock = ssl_wrap_socket(
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\util\ssl_.py:470 in ssl_wrap_socket
    ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls, server_hostname)
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\util\ssl_.py:514 in _ssl_wrap_socket_impl
    return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
  File ~\AppData\Local\Programs\Python\Python312\Lib\ssl.py:455 in wrap_socket
    return self.sslsocket_class._create(
  File ~\AppData\Local\Programs\Python\Python312\Lib\ssl.py:1046 in _create
    self.do_handshake()
  File ~\AppData\Local\Programs\Python\Python312\Lib\ssl.py:1321 in do_handshake
    self._sslobj.do_handshake()
SSLError: [SSL: UNSAFE_LEGACY_RENEGOTIATION_DISABLED] unsafe legacy renegotiation disabled (_ssl.c:1000)
During handling of the above exception, another exception occurred:
Traceback (most recent call last):
  File ~\Python Projects\myenv\Lib\site-packages\requests\adapters.py:486 in send
    resp = conn.urlopen(
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\connectionpool.py:844 in urlopen
    retries = retries.increment(
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\util\retry.py:445 in increment
    raise reraise(type(error), error, _stacktrace)
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\util\util.py:39 in reraise
    raise value
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\connectionpool.py:790 in urlopen
    response = self._make_request(
  File ~\Python Projects\myenv\Lib\site-packages\urllib3\connectionpool.py:491 in _make_request
    raise new_e
  File ~\Python Projects\myenv\Lib\site-packages\cognite\client\_http_client.py:151 in _do_request
    res = self.session.request(method=method, url=url, **kwargs)
  File ~\Python Projects\myenv\Lib\site-packages\requests\sessions.py:589 in request
    resp = self.send(prep, **send_kwargs)
  File ~\Python Projects\myenv\Lib\site-packages\requests\sessions.py:703 in send
    r = adapter.send(request, **kwargs)
  File ~\Python Projects\myenv\Lib\site-packages\requests\adapters.py:530 in send
    raise SSLError(e, request=request)
The above exception was the direct cause of the following exception:
  File ~\Python Projects\myenv\Lib\site-packages\spyder_kernels\py3compat.py:356 in compat_exec
    exec(code, globals, locals)
  File c:\users\ravi.bhagwat\testpy.py:29
    token_info = client.iam.token.inspect()  # 'iam' stands for: Identity and Access Management
  File ~\Python Projects\myenv\Lib\site-packages\cognite\client\_api\iam.py:406 in inspect
    return TokenInspection.load(self._get("/api/v1/token/inspect").json(), self._cognite_client)
  File ~\Python Projects\myenv\Lib\site-packages\cognite\client\_api_client.py:149 in _get
    return self._do_request("GET", url_path, params=params, headers=headers, timeout=self._config.timeout)
  File ~\Python Projects\myenv\Lib\site-packages\cognite\client\_api_client.py:217 in _do_request
    res = self._http_client_with_retry.request(method=method, url=full_url, **kwargs)
  File ~\Python Projects\myenv\Lib\site-packages\cognite\client\_http_client.py:135 in request
    raise e
  File ~\Python Projects\myenv\Lib\site-packages\cognite\client\_http_client.py:115 in request
    res = self._do_request(method=method, url=url, **kwargs)
  File ~\Python Projects\myenv\Lib\site-packages\cognite\client\_http_client.py:169 in _do_request
    raise CogniteConnectionError from e
Best answer by DeelakaCS
Resolution Summary
Issue: User having an issue when using Python SDK notebook.
SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate in certificate chain (_ssl.c:1000)
Assumed that company network setting might blocking API calls to CDF endpoint.
Asked the user to try SDK notebook using a personal laptop and personal network.
The user informed that the SDK notebook works on personal laptop.
Solution: The issue was resolved by installing pyopenssl using "pip install pyOpenSSL"
  • January 30, 2024
Hi @RaviBhagwat,
I have created a support ticket. The team will look into this and follow up on it.
Br,
  • February 8, 2024
Resolution Summary
