Aggregate function of average not resulting the correct value
  • October 5, 2023
  • 56 views
Hello Cognite team,
Greetings! Below is a screen shot of 4 data points available for a specific timeseries id in a duration of 1 hour
For the above mentioned data points when i select the aggregate function (similar value being resulted from aggregate function api) i see an average value which is significantly higher than the original value (calculated manually) The data interval for the below points is for every 15 mins the first 4 data points for this timeseries is what you see in the below screen shot
Best answer by Dilesha Kodithuwakku
Hi @Manish Nethi ,
The average aggreation in CDF is defined as the ntegral of time series divided by the size of time range. So the average function computes the time-weighted average value of the time series per time range. Please refer to the documentation for further information.
Dilesha
Hi @Manish Nethi ,
Dilesha
  • October 12, 2023
Hi @Manish Nethi,
Did the above help you?
