How do I know which direction Spot will face at each waypoint in InRobot 3D?
  • July 6, 2023
  • 49 views
With so many waypoints in the 3D model, how do I know which direction Spot will face at each waypoint?
I could know actually making Spot move to the waypoints, but I would like to know within the inRobot 3D model without moving Spot.
In case Spot passed through a narrow area several times, several waypoints were generated witch Spot facing different directions.
In this situation, it is not clear which waypoint to select when creating a mission within InRobot. If we create a mission by selecting a waypoint with the wrong direction, Spot will walk while spinning.
Best answer by Elias Bjørne
Ishikawa, thank you for reaching out! This is a very good point. We are storing the direction in the waypoints, but are currently not visualizing it. Just a quick question. Is the direction most relevant when you want to choose a  waypoint. or do you want to see directions for all waypoints? Regardless, we will have a look and we will give you a timeline for when a solution could be available. Again, thank you for reaching out!
  • July 6, 2023
@Elias Bjørne
Thank for your reply.  I’d like to see all waypoints directions.
If the direction icon are displayed to all waypoints, it may be obtrusive. So it will be nice direction display on/off option.
