Error while setting up environment for "Extractor-utils Library for Cognite Python SDK"
  • July 17, 2024
  • 130 views
first of all i created a new environment with below codes.
python -m venv env
env\scripts\activate
pip install poetry
poetry config virtualenvs.in-project true
pip install pandas numpy
pip install cognite-sdk
pip install "cognite-sdk[pandas, geo]"
pip install cognite-extractor-manager
once all above code completed. I started running cogex init.
I am getting below error.
cogex init
Enter extractor name: csv extractor
Enter description: desc
Enter author: --I provided the cognite login mail id in name <mail id>
Which template should be loaded?
  simple: loads a generic template suitable for most source systems, using
          a simple function as the main entrypoint for the extractor.
          Most suitable for small and simple extractors.
  class:  loads a generic template suitable for most source systems, using
          a run method on a class as the main entrypoint for the extractor.
          Most suitable for slightly bigger and more complicated extractors.
  rest:   loads a template for extracting from RESTful APIs, using the REST
          extension for extractor-utils
Enter template (simple/class/rest) [default: simple]: simple
Fetching gitignore template from GitHub
Initialized empty Git repository in C:/Users/QY857BZ/Downloads/Python Enviroments/Extract/.git/
Requirement already satisfied: pip in c:\users\qy857bz\downloads\python enviroments\extract\env\lib\site-packages (24.0)
Collecting pip
  Using cached pip-24.1.2-py3-none-any.whl.metadata (3.6 kB)
Using cached pip-24.1.2-py3-none-any.whl (1.8 MB)
Installing collected packages: pip
  Attempting uninstall: pip
    Found existing installation: pip 24.0
    Uninstalling pip-24.0:
      Successfully uninstalled pip-24.0
Successfully installed pip-24.1.2
Using version ^7.2.3 for cognite-extractor-utils
Updating dependencies
Resolving dependencies... (3.9s)
Package operations: 21 installs, 0 updates, 0 removals
  - Installing pywin32 (306)
  - Installing portalocker (2.10.1)
  - Installing azure-core (1.30.2)
  - Installing isodate (0.6.1)
  - Installing msal-extensions (1.2.0)
  - Installing setuptools (70.3.0)
  - Installing types-python-dateutil (2.9.0.20240316)
  - Installing altgraph (0.17.4)
  - Installing arrow (1.3.0)
  - Installing azure-identity (1.17.1)
  - Installing azure-keyvault-secrets (4.8.0)
  - Installing dacite (1.8.1)
  - Installing decorator (5.1.1)
  - Installing orjson (3.10.6)
  - Installing pefile (2023.2.7)
  - Installing prometheus-client (0.20.0)
  - Installing psutil (6.0.0)
  - Installing pyinstaller-hooks-contrib (2024.7)
  - Installing pyyaml (6.0.1)
  - Installing cognite-extractor-utils (7.2.3)
  - Installing pyinstaller (6.9.0)
Writing lock file
Using version ^1.10.1 for mypy
Using version ^0.5.2 for ruff
Using version ^3.7.1 for pre-commit
Resolving dependencies... (0.8s)
Package operations: 7 installs, 0 updates, 0 removals
  - Installing cfgv (3.4.0)
  - Installing identify (2.6.0)
  - Installing mypy-extensions (1.0.0)
  - Installing nodeenv (1.9.1)
  - Installing mypy (1.10.1)
  - Installing pre-commit (3.7.1)
  - Installing ruff (0.5.2)
Writing lock file
Resolving dependencies... (1.6s)
Installing dependencies from lock file
No dependencies to install or update
Installing the current project: csv_extractor (1.0.0)
An unexpected error has occurred: CalledProcessError: command: ('C:\\Users\\QY857BZ\\AppData\\Local\\Programs\\Git\\cmd\\git.EXE', '-c', 'core.useBuiltinFSMonitor=false', '-C', 'C:\\Users\\QY857BZ\\AppData\\Local\\Temp\\tmpekei_omx', 'fetch', 'origin', 'HEAD', '--quiet', '--filter=blob:none', '--tags')
return code: 128
stdout: (none)
stderr:
    fatal: unable to access 'https://github.com/charliermarsh/ruff-pre-commit/': SSL certificate problem: unable to get local issuer certificate
Check the log at C:\Users\QY857BZ\.cache\pre-commit\pre-commit.log
pre-commit installed at .git\hooks\pre-commit
error: `ruff <path>` has been removed. Use `ruff check <path>` instead.
warning: The top-level linter settings are deprecated in favour of their counterparts in the `lint` section. Please update the following options in `pyproject.toml`:
  - 'dummy-variable-rgx' -> 'lint.dummy-variable-rgx'
  - 'fixable' -> 'lint.fixable'
  - 'ignore' -> 'lint.ignore'
  - 'select' -> 'lint.select'
  - 'unfixable' -> 'lint.unfixable'
Please can you all help in fixing the issue
Isha Thapliyal
Forum|alt.badge.img+5
  • July 19, 2024
Hi @Vipul Gupta
Thank you for your question! We've moved it to the correct group to ensure it gets the attention it needs.
It will be reviewed soon, and we'll work on providing you with a resolution.
FYI ​​​​@Dilini Fernando
Thanks
Isha
Forum|alt.badge.img+8
  • February 24, 2025
@Vipul Gupta is this issue resolved?
