Streamlit Queries
  • August 16, 2024
  • 37 views
A few queries on Streamlit Application :
  1. Since this Streamlit application is integrated within Cognite, is there a URL that can be shared with others to access the Streamlit dashboard?
  2. Is there a method to effectively organize and filter the content within the application?
Best answer by Udantha Wijeweera
Hi @Bonthala Anvitha
For you first concern see if the below guide helps you;
Once you publish your application in Streamlit through CDF
This application will appear in the Custom Apps in the industrial tool
Then you can click on the application and you will have an option to share were you will get a QR and a link as well. Note that anyone who access to CDF should be able to view this.
For the second point:
I’m not quite sure if I understood your concern there if you can elaborate more on your application use case I might be able to help.
But you can refer to these documentations below to get an idea on filtering techniques:
https://cognite-pygen.readthedocs-hosted.com/en/latest/usage/listing_filtering_retrieving.html
I hope this helps. Have a great day!
Best,
Udantha
Best,
Udantha
