"Create Data Set" option is not available
  • June 21, 2024
  • 23 views
In the Cognite Data Fusion Fundamentals path, there is a hands on learning course where I need to create a data set; however, it seems like the UI has gone through a couple of iterations since and I don’t see the `create data set` option based on the path provided in the course.
These are the instructions that were provided.
This is what the UI that I currently see. (It’s possible my account doesn’t have the right access to create the data set)
Can someone please help?
Best answer by kliang
Turns out the top left is a clickable drop down. Resolved.
  • June 21, 2024
