Error from replicating Transform RAW to events - Working With CDF: Integrate lesson
while attempting to run
SELECT
workpackage_desc AS description,
to_timestamp(completion_time/1000) AS endTime,
to_timestamp(start_time/1000) AS startTime,
type,
subtype,
concat('FirstnameBirthyear:',key) AS externalId,
1234567890 AS dataSetId
FROM IFSDB.maintenance
WHERE to_timestamp(completion_time/1000)>to_timestamp(start_time/1000)
I get this error
Verify that the 'IFSDB.maintenance' relation exists | code: 400 | X-Request-ID: 019f535a-a30f-9184-b3d3-966184e9d36b
Note that:
  • I substituted my Name and birthyear
  • changed the dataset id
My assumption: sure I have a IFSDB.maintenance RAW (not sure if I skipped something in the lesson...)
Hi @CLP,
I hope Sofie’s reply was helpful. As of now, I will close this thread. If you have any questions, please feel free to reply here.
Sofie Haug
Forum|alt.badge.img+7
  • 161 replies
  • June 8, 2023
Hi @CLP
Which CDF project are you working in?
Sofie Haug
  • 161 replies
  • June 8, 2023
As long as you use the “cdf-fundamentals” CDF project, this relation should exist.
  • June 9, 2023
I am in the integral-sandbox (Aker Solutions account).
SQL query used:
SELECT
type,
subtype,
concat('Claudio1989:',key) AS externalId,
8093985164902606 AS dataSetId
Error that I get
Verify that the 'IFSDB.maintenance' relation exists | code: 400 | X-Request-ID: 97949733-e8f7-91b5-aa3e-721f23926e90
I am sure I am doing something stupid and naive here… :)
Sofie Haug
  • 161 replies
  • June 12, 2023
Okay. Then this makes sense! The database and table we are reading from is pre-uploaded in the project used for the course. But what you can do if you want to continue using the Aker Solutions sandbox is to create a database called “IFSBD” and a table called “maintenance”.
This has to be done for time series and datapoints as well. You do the same as when you created your FirstnameBirthyear database and “assets” table.
Remember to use the correct names.
Database: IFSDB
Table: maintenance
Under the same database you can create the table “sensors” for time series and “values” for datapoints.
  • June 27, 2023
Hi @CLP,
