Unable to select version of workflow from the UI
  • 5 November 2024
  • 30 views
Hello,
We are unable to select version of workflow from the UI. for instance here we are at version 0.0.39 and in the UI the workflow is at version 0.0.1.
I think this might be an UI issue.
Jørgen Lund
  • Product Manager
  • 103 replies
  • November 6, 2024
Hi @Marwen TALEB. Yes, this is unfortunately a UI issue. We’re working on making the version selectable in the UI, and to make versions in general better integrated in to the user experience.
Until then, I’d recommned using integer version numbers, i.e. “1”, “2”, and so forth. This should be compatible with the current functionaltiy in the UI.
